King 6000 stone
What do you mean it doesn't work? The discoloration may be the way it dried I had something like that happen to mine I got worried about but it dried out
You can use some medium-grit silicon carbide drywall sanding screen on a piece of flat glass or stone as a cheap flattening plate.
It sounds like it needs to be lapped... and yes, you can use coarse sandpaper.
I soak 2 nminutes before use. One time i permasoaked for 15 days. It stopped working after that.
It's not going to just stop working because it was in water. I have stones that have been in water for over 5 years with no ill effect, Kings included.
Hmmm, I wonder if the steels its being used on is part of the problem.
To the OP, have you tried it on a couple of different knives with different steels?
Finishing stones like that king 6k only enhance a sharp edge from a previous grit. Also they load fast and glaze if not used properly.
I've had mine discolor slightly from being soaked in bleach water for a long time.
I'd be thinking it got contaminated with oil.
