- Feb 28, 2007
Seriously this thread is like asking crack addicts if a pipe and lighter is really necessary. Mac
Nope, pipe, knife, hearth, drill, bow and piece or paracord will do ya fine!
SAK and a box of matches.I am to old for the primitive fire starting.
Blowtourch? That is an old indian trick, all of us old indians use it.
In a pinch, zippo fluid will work.![]()
I'm not above using Zippo fluid, nowadays. Sometimes I wish I still had C-4: just peel off a chunk and light it. It was a pretty good fire starter, once upon a time. Still, a blowtorch would be better, if it didn't weigh so much.![]()
Honestly, i did read much past the 1st page.
My personal belief is "It's better to have and not need then to need and not have."
To be honest I tend to think of the often used expression "two is one , one is none along the same lines. Where does it reasonably endThis is a statement that gets used a lot (for different items).... My only problem with this mentality is it poses many other questions regarding gear choices.
Do you carry.... a gun?... bear spray?... back-up blades?... GPS?... PLB?.... etc....
all those fall under the same category, IMO.
Empty nasal spray botttles filled with alchol work well, Just don't get the bottles mixed up, or mark them well. WHOZERS.![]()
C4 was good substitute for Hex tabs too.![]()
Mick... nice:thumbup:..... but don't throw math at me this early, brother... that is uncalled for.
Rick![]()
Improvising a cutting edge isn't rocket science. It doesn't have to be art either since it isn't going to be an accurate airborne projectile. It doesn't take much skill to find an already sharp flake of chert, flint or other stone. It doesn't have to be shaped like a modern knife and doesn't have to be hafted.
Without said "jive" skill, what will you do when your knife gets lost or stolen? Reach down and pick up a sharp rock, or strike two round rocks together to percuss off a conchoidal flake?
Like a more "refined" knife that resembles a modern one? Learning to knap and haft isn't beyond the abilities of most children, and certainly few teens can't master it. Sure, it takes a little bit of effort. But there is comfort in knowing that if you find a loose thread, you won't die if you've lost your knife.![]()
I didn't say learning to knap was hard. I said if you know nothing about it, which most people don't, and find yourself in a survival situation, knapping isn't going to help. There is more to knapping flint than hard rock/flaky rock, and there is more to a knife than a cutting edge. I didn't say anything about dying without a knife, survival is much more to do with whats inside than whats in the hand. If I lose my knife in the woods, I'll use the other one I carry. If I lose that, I'll use the other one. If I lose all my knives (which don't weigh lbs by the way), i'd try my hand at knapping (if I had to). This isn't an argument that can be won be either of us. I would rather have a tool to help make a bad situation more comfortable (even if its only mentally)...and for me thats a knife, or two, or three.
