LB7 question
First post in this sub-forum (I’m mostly a Buck 110 carrier — blasphemy here, I know). Back in the early-to-mid 1990s there was an old fashioned hardware store, Wal-Lex Hardware, that sold a variety of knives in the case and in those cardboard displays. I was working on a fishing boat during my summers and I would buy a knife here and there from that store. I had a couple Colonials, Imperial Kamp Kings, some Imperial Ireland pocket knives, and a bunch of Schrade Old Timers and Uncle Henrys, mostly stockman knives or little two blade Jack knives. I always wanted a Buck 110, but they were a little more expensive and I had to go into Boston or to a sporting goods store. I bought an LB7 and one of the Old Timer sawcut delrin barehead versions (I forget the model number). I carried that the most because it had a lanyard hole and I would tie the lanyard to my belt when I was on the boat. I used it fishing and when I worked for a custom cabinet maker. I lost it in the Charles River one day and just never replaced it. I don’t know what happened to the LB7. My mother probably tossed it after I left for college in Florida.
At any rate, in the last few years I’ve acquired a few USA-made LB7s here and there. I’ve been trying to find some info on them, especially the approximate age or each knife.
I read this post:
My understanding is that the serial numbering of the LB7s ended sometime in the 1980s.
Here are mine:
The one on the left is the most modern: the tang stamp has the script “Uncle Henry” over “Schrade +” over “LB7 USA”
Second from left is serialized: A25568 or AA25568 — it’s hard to make out of there is a first A because of scratches on the bolster.
Third from left is also serialized: 032353 or Q32353.
The last one I received with those modifications. I replaced the thumb stud with something better than what the previous owner had used. It’s loose, with both side-to-side and vertical play. It is a 4-pin model and it too is serialized: 19796.
I’m not a collector — more of an acquirer — and I use my knives. With that said, though, I like to know some background on my knives. Any information on the date range of the knives, or steel type (if not 440A) you folks can share would be terrific.
