Well, after using Hoppes gun oil to lube my mini mags for years, I finally switched over to silicone lube. Some simple dielectric grease down on the end cap, since those threads are conductive surfaces, and some Syl-Glyde (or something like that; from Napa) on all the other threads and o-rings.
Now, everything feels a little tighter than it did with the Hoppes, which makes sense since the silicone greaseis much thicker; though I think with time it'll loosen up. But it does seem I've picked up a little brightness after the switch. I figure thats likely, as I cleaned all threads and o-rings real good, notably getting all the Hoppes off the end cap threading and replacing with current-freindly dielectric grease. Now I should never have to deal with crapped out o-rings, and I'm hoping that it'll go longer between lubes (which is already in the multiple years between apps). I am worried the silicone will pick up more crap than the Hoppes did, though; but hopefully the tolerances around the head are tight enough to negate this... we'll see!
