The blade style I feel is misleading.
When you make a blade with less width I feel it will take on a whole new look.
The wee hawk is my fav blade of all time on the balis.
As for a hand rubbed satin finish that can be arranged. I will talk to Kevin and Chuck to confirm the price. The problem is the 420v.
It is a real job to hand satin finish.
As for hollow grinding well I am a flat grinder. I like the strength of a flat grind much more. Balis have a dropping problem..
from the user. I feel the flat grind will accomadate this problem much better.
Asfor blade shape once again if the blade finish is of concern I will get with Kevin and add the hand rubbed satin. We were trying to keep the price point as low as possible with the field satin finish.
The recurve will be slight at best. It can be removed before final grinding if you want. That is not a big concern. Just tell Kevin at order time.
I feel if you order and have a bit of faith the blade shape will be pleasing and functional.
The bowie style is not a problem . Without a top clip the knife blade may be right in line with what you want. Also the blade may be changable to your likes from the standard blank. I do not laser or Wj cut. I make them here so its not a great deal of extra work if the blade can be modified from the original.
I hope this clears up the extra concerns.
I am considering the stub style that Steve has modified also (latchless).
Any thoughts on the serrated handles?
Need input here from the folks that use the knives..
Web Site At
www.darrelralph.com
