Nope! Havent given up yet! NEVER! I know ive been running my mouth a lot lately but ive been running my tools as well
Wifes away this this dog's gonna play!
Got them 1911 bushings in Bawanna! Great idea! Them threads are way fine. 236 tpi
Had to chuck the tap up in the drill press and manually turn it to get it aligned and tapped but went flawlessly:thumbup:
Then I drilled and counterbored the scales. That wasnt so much fun but it got done. I can tell i need to set something up proper if Im gonna do that again. Really needs to be done on a mill. Sloppy arse chinese drill press just dont get it. I really need a mill.
Anyway while i was on the sloppy drill I counter bored for the bearings. Another mil task. I managed to get a forstner bit to work but not pretty. Only worked because it was brass.
Scales fit pretty good once the bushings were installed. Not perfect but good enuff for first time. I can always make another set of scales anytime.
Time to cut off all the vertical stuff from the scales. I had to make a sanding drum and use sticky paper to get the inside radii. worked pretty well.
Done with the vertical stuff. Next is take off some scale thinckness. Actually ive already done that but im behind on posting pics and stuff so that will come on next update. Im cutting bevels on the scales now. This is the scary part? No idea how this is going to turn out. Had to let the dust settle in the shop so figured id post some pics and update.
