Looks nice. Good job. Do you know what angle it's at?
Looks good I still need to sharpen mine. You do that with an Edge Pro?
The finish off stone is 1500 grit. Then on a sliding scale, 600, 300 and 120. If the 120 tends to tear off carbides out of the S35VN, I can always start with the 300 to reprofile the edge back to 20 degrees by making many more passes with the 300 stone and then onto 600.
Adam, I know that you use Wicked Edge hence the ability to go to 15 dps and then the 20 micro. I opted for KME which goes only as low as 17 dps.
My Carothers D2 is not even fair completion to anything else I own for eviscerating cardboard and yet just keeping its toothy edge. Well, I suppose that the Zaan will just have to be sharpened with a guided system to achieve better bevel and edge uniformity as opposed to my freehand "skills" and then set aside for other tasks. Quite honestly it has not been the same Zaan after I foolishly cut a rather heavy duty patio umbrella box!
KME can go below 17 dps. You can either put the clamp back further on the knife spine (thereby making the angle shallower) or you can turn the rod holder upside-down. Admittedly, an angle cube helps.
Lansky's diamond course hone is 120 grit, I've actually pulled carbides out of the steel using this stone. It happened on two occasions. I'll never use it again, the steel was Z-Ware and M390. I'll take more time to reprofile rather than run into taking a risk of tearing steel out. I guess I'm gun shy now. Depending on the reprofile, I'd be leery of using an aggressive course stone.
I've never used my KME to reprofile an edge of any significance, just a degree or two and it does the job.
What's your finish grit stone? For cutting stuff, I stop at 400 or 600 grit. I've found that a toothy edge helps keep the edge longer for a working knife.
