BTW, how the heck do the Victorinox can openers work?
mb
It's also possible to use the Vic can opener in the other direction.
How is this style of can opener used?
So what looks like a one-handed pen blade is actually a can opener?
So would the can opener on a Leatherman Wave cut forward or backwards. I always guessed it would be backwards.
Yes, "beak" style can openers cut backwards.
adam
I was replying to ChapmanPreferred....
I know exactly the type you are referring to and their use has puzzled me as well. The handle can only be moved one way, or else the can opener will fold shut. I believe that holding the knife in the same grip you use with a Vic can opener, you puncture with the tip of the hook-thingy in an almost verticle move and almost fully insert the tip while moving the point forwards so now the tip is within the can and the square piece is on top, the knife handle is almost horizontal. Then rest the square piece on the top lip of the can and pull upwards on the handle. That should cut the piece of can that is between the hook and the square piece. Then proceed forwards around the can. Course I've never tried one of these, just thinking about the design how it's probably used.
adam
This is where being a lefty helps. 1st. hold the point vertical & push straight down. 2nd hold the knife SPRING-SIDE DOWN (in you left hand). 3 lift & advance then repeat.
You cut upward thru the can not down ward. The hooked end on the opener wasn't for cans but for struck rifle cartridges (in fact Remington patented it as such).
think it's easier to use than the beak style or Vic SAK style, but I've been told I'm odd.
The Mirando 1945 "safety" opener and the Victorinox opener both cut the can lid by moving from topside to bottomside, but the Mirando opener is pulled backward for the next cut, while the Victorinox is pushed forward. The Rough Rider opener cuts from bottomside (inside) to topside (outside), by pushing the handle down. It is then pushed forward for the next cut. Note that these blades are all hinged in a way that allows the handle to exert force on the blade, without folding. I wish the Rough Rider opener was a safety opener; upward cutting blades create dangerously sharp edges sticking up from the can lid. The recently re-introduced Remington boy-scout knife also has a nostalgia blade that is more dangerous than it needs to be.
