choombak
- Jun 6, 2009
I recently received the Fantoni HB 02 from a Finnish dealer, in about two weeks from order. For under $200, this is one of the best fit and finish I've seen on a production knife.
Knife blade is about 3" (this is the smaller version, the larger one is HB 01), a good blade to handle ratio, and very tight tolerances. It snaps open with no other squeaks except for the lockbar engaging. The liners are titanium, with bead blasted hardware, though the blade has a light stonewash. The titanium clip is super tight, and I'll have to bend it outwards for a comfortable clip. With dual thumstuds, and jimping on the liner lock, its a pleasure to open and close. Blade steel is stamped S35VN (though the literature reads S30V), and has the name of the designer stamped on it (haven't seen any other production knife with the maker's full name). Scales are G10, grippy, but not overy aggressive (two colors available, black and tan/brown). The butt of the handle also has jimping with gradually changing diameter (see photos). Blade is shaving sharp out of the box.
My initial impressions are very positive, I'll update this review after a month or so of using it. Enough chat, I'll let pictures do the talking... (shot with a Panasonic Lumix LX7 on fully auto mode):
Innovative packaging
Included literature (Italy follows the Metric System, hence all measurements are in mm, rather than inches)
Notice the internal pattern of the pivot screw
Notice the butt-end jimping that gradually increases in diameter
Fit and finish is superb
Jimping on the liner lock
Perfect engagement
Centered blade
Perfect engagement
Centered blade
