- Jan 9, 2011
Here's my setup... a heat treated piece of steel with a precision .1875" hole to index from. I use a reamer that matches the hole size... run the mill with the quill down so the reamer floats in the hole and clamp the blade. After that the pivot hole is indexed and I change the reamer to a 5/16" bit to drill out the pivot. The pliers hold the pivot and keep it from spinning.
I'm also simulating a rotary table with this method, it works very well for concentric holes...
I use the cordless drill and precision drill bit blank to turn down the G10 inlay... turn it fast and check a ton so it just fits.
Inlay glued up!
Done! That's a smudge of oil, not a scratch! I mirror polished it but like the satin better with G1O.
Inlay glued up!
