but now I am somewhat confused (what else is new)OK, when using stones, they should be dry, even if they are oil or "wet stones"??? Yes or no.
Most of us don't use oil even on oilstones -- we either use them dry or use water.
Don't let my post above scare you away from using water -- just wipe the knife off and oil it when you're done -- and if the phone rings wipe it off before you answer the phone.
To take a stain finish and remove the fine scratches and restore the finish to a mirror, I need to NOT rely on Jeweler's rouge but need a little more abrasive compound???What?
Rouge is for finishing; it would take years to polish out a deep scratch with it. There are a lot of faster-cutting polishes around; in fact just about everything cuts faster than rouge.
I personally don't like rouge even for finishing -- it does work; it's been used for thousands of years to polish metals, glass, and gemstones -- but it has a nasty tendency for the particles to clump together and make sleeks. You're almost to a perfect mirror finish and then the damn stuff makes a sleek and you have to polish that out, and while you're doing that it makes another sleek ... I hate the stuff. Some people like it, though; YMMV.
I usually finish with tripoli compound on leather. If I want a finer polish than that I use Raybrite A, a submicron aluminum oxide that's available from rockshops. We all have our own pet methods, though; and most of them work -- my way is not the only way.
To Strop, It's best to use the UNFINISHED side of a belt.
That is an endless argument -- people have been arguing whether the smooth side or the rough side of the leather is better since the neolithic revolution and I expect they will still be arguing when the sun expands into a red giant 6,000,000,000 years from now. There's no reason they should ever stop arguing about it because it makes no difference.
If you're using an old belt that's painted on the smooth side don't use the painted side, though -- unless you remove the paint.
Load it with Jeweler's rouge????
Whatever polish you use you don't need much of it. When you first load the strop with polish and start stropping the polish gets rubbed into the pores of the leather and the excess falls away and then you're all set for a long time to come. It may look like there's no polish left on your strop but there is, and if you put more on it won't work any better.
And as far as the Dremel to restore that fine morror finish that I like, I REALLY enjoy the Dremel. I just cannot figure out how to NOT end up with those damn swirls.
Finish stropping by hand. Or do it all by hand in the first place ... Dremel tools are really not labor-saving devices.
