- Feb 4, 2015
If two identical blades - say 1084 - are heat treated 2 different ways...
Blade A - Professionally heat treated to a near optimal hardness - say Rockwell 63 - by holding at the nearly ideal temp for nearly the ideal time and then quenched in the ideal quenchant.
Blade B - Heated to about the right temp and then quenched in salad oil to Rockwell 59.
Both blades are then tempered to RW 57 using the same number and times of tempering, but at different temps to reach the same hardness.
How would they differ?
I speculate that they would both take and hold an edge about the same but that blade A would be less likely to break. But I don't know that - which is why I am asking.
Thanks.
Thanks.
