- Feb 28, 2002
[youtube]U0J0O0tz3v0[/youtube]
There are some in the knife community who should be reminded of these facts regularly. Unfortunately they are often those least likely to listen to the voice of reason. Well stated Phil, I look forward to more videos from you.
I think you are absolutely correct that it is wrong to base the evaluation of a tool solely on performance of tasks that it was not meant to be used for.
Let's imagine that one is comparing a range of relatively similar tools in order to render a comparative analysis. For the sake of argument, let's assume that all the tools' manufacturers make essentially the same claims for their products, and issue essentially the same use directives.
Let's also assume that some of the tools demonstrate broader utility outside the prescribed range than some of the other tools. That is a legitimate asset of the former tools as opposed to the latter. And that is a valid reason to render a favorable critique of the former.
It might be that a given prospective buyer has no interest in the non-prescriptive performance. In that case, the buyer will likely disregard that aspect of the evaluation.
There is nothing wrong with testing to failure, but the case here appears to be people dismissing absolutely great knives just because they can't be beat through brick.
Those that are stating this obviously need to reread the thread in question.I don't recall reading that anyone dismissed any knives from purchase consideration simply based upon upon any one person's review.
Anyone testing past a makers suggested use should expect to own a broken knife.
"Common Sense" goes hand in hand with the idea of "Reasonable Use".I agree with that :thumbup: Unfortunately when it comes to some of the larger fixed blades we don't get much information from the makers regarding suggested use. I think it would be great if it was clearly stated, for instance, that a knife wasn't intended to be batoned at all, or was intended to be batoned lightly with wood but just not to be cross-grain batoned, or was made to be batoned with anything that was at hand, or can be batoned with and through just about anything. It would surely clear up a lot of the confusion that results when a knife is generically labeled as tough.
If it seems like "Abuse", then it generally is.
