- Feb 15, 2014
Our new model J.A.C.K. which designed by our designer Jack Chen finally came out and will be available at our dealers this week.
We would like to share the details about this model here with you.
The name "J.A.C.K." was suggested by Rainer Wenning when at 2018 IWA Show.
It means: Just a compact knife as well as because of the designer Jack Chen.
Specification:
Bearings: Double row ceramic ball bearings
Integral handle
Open Length: 9.25”
Blade length: 3.94”
Closed length: 5.24”
Blade thickness: 0.157”
Blade material: Bohler M390/Damasteel
Blade material hardness: 61HRC
Handle material: 6AL4V Titanium
Inlay material: Marbel Carbon Fiber/Brass
Weight:250g/8.82oz(brass inaly)
200g/7.05oz(marble CF inlay)
Blade finish: Satin finish M390/Acid wash Damasteel
Handel finish: Gray(Bead blast)/Anodized bronze
/Anodized blue/Flame grain
Locking:Frame Lock
There are 16 versions of this model and limited with about 650 pcs in total.
Here are some photos for the J.A.C.K.
1. Bead blast handle/Marble Carbon fiber inlay + M390 Blade
2. Bronze handle/Marble Carbon fiber inlay + M390 Blade
3. Blue handle/Marble Carbon fiber inlay + M390 Blade
4. Flame grain handle/Marble Carbon fiber inlay + M390 Blade
5. Bead blast handle/Marble Carbon fiber inlay + Damasteel Blade
6. Bronze handle/Marble Carbon fiber inlay + Damasteel Blade
7. Blue handle/Marble Carbon fiber inlay + Damasteel Blade
8. Flame grain handle/Marble Carbon fiber inlay + Damasteel Blade
9. Bead blast handle/Brass inlay + M390 Blade
10. Bronze handle/Brass inlay + M390 Blade
11. Blue handle/Brass inlay + M390 Blade
12.Flame grain handle/Brass inlay + M390 Blade
13.Bead blast handle/Brass inlay + Damasteel Blade
14.Bronze handle/Brass inlay + Damasteel Blade
15.Blue handle/Brass inlay + Damasteel Blade
16.Flame grain handle/Brass inlay + Damasteel Blade
Reate Knives would like to talk a little bit about one important techniqueFreeze Edging Skill.
As the final process for a blade, edging has a great effect on the performance of the knives, after all, the edge part is the main function area when using a knife. Normally, edging is operated on a high-speed running grinding wheel or grinding belt, which produces a very high temperature. Without a cooling system, the temperature on the edge goes up instantly to hundreds of centigrade, when it gets worse, it will burn and leave heat marks on the blade. Tempering or even annealing will happen on area of the edge where the temperature increasing instantly. It will harm the hardness and durability of the blade. Thats why some knives passing the hardness standard test but still easily get worn in actual use.
Reate Knives are using the freeze edging technique. During grinding, the temperature on the edge is controlled in a certain level of degree, which helps keep the hardness after the heat treating. Therefore, the sharpness and durability of the blade are assured. This helps bring the performance of the material to the best.
Thank you very much for your time.
Reate Knives Team.
Specification:
Integral handle
Open Length: 9.25”
Blade length: 3.94”
Locking:Frame Lock
Reate Knives Team.
