- Apr 1, 2013
Huh?Look again...
Huh?Look again...
John hid this little gem:Huh?
Change of plans for this 3rd run, @CoryMc you'll move into this slot if you're ready. I'll need a handle material, sheath type, and right or left hand. I have denim micarta to offer also as a handle choice. Let me know if you have questions or concerns
FYI if anyone needs to buy themselves a little time and would like to bump down, I'm good with that just let me know and I'll adjust the list (which can be found here). Thanks everybody.
Didn't see that, thanks.John hid this little gem:
You're very welcome.Didn't see that, thanks.
Hmmm, clip sheaths will need to be ordered by pocket preference. For example, I'm right handed but would carry a clip sheath in my left pocket with the edge facing out. So I would order a Left Pocket Carry.... That's not necessarily right or left handed.
My concern is that an ambidextrous sheath won't have solid retention if you swapped back and forth and would have to be a larger sheath. Just thinking aloud, you're welcome to join in on this.
Would it be possible to put a pocket clip on one of the regular belt-loop sheaths?
Yes I’ve seen them and I keep kicking around the idea of trying them on some of my smaller fixed blades.Have you seen these clips? Well recommended by both Horsewright and Delta Sheath here on BF. Different sizes and some suitable for knife sheaths. Shown here in use on a sheath by @DeltaSheath. They look like a very nice option.
A belt loop with a clip might be one of those combinations that does neither thing well. With the sheath slid on a belt, and the clip against your body it may get bent, start to wear into your pants, or just be terribly uncomfortable and poke you all of the time. If the clip were on the opposite side if the belt loop, it would catch on things and probably be awkward I'll look into it amd consider some options but I'm not sure a happy medium (hmmm, medium or median?) could be found that isn't awkward either way.
How big of a belt would those current clips fit over?
Thanks Ray. I am familiar with those, but I'm talking about the clips John already has.Check the link in my thread above (with the photo). There are 3 sizes that seem suitable for knife sheaths, from short and narrow to taller and narrow or taller and wide - then bigger still.
You got it, I'm running these in pairs sonit looks like you'll be in the 9th set. Welcome to the sub and thanks for the interestCan I call dibs on seat #10 please? I’ve been scrolling through these threads admiring your work. Thank you.
