Unless I am wrong these are sharpened on sander belts by hand. this results in the convex edge and the variance
I had heard that the secondary bevel was convex? Is there any truth to this? One reason to doubt that it was convex is that at one point the CRK website recommended using a Sharpmaker to sharpen CRKs which would do away with the convex grind.
Yes, CRK do convex grind their edges. And they still do recommend using sharpmaker for maintaining the edge only on the 40 inclusive side
This is going to sound like a stupid question but is 40 degrees on a Sharpmaker the closer or wider the sticks are apart?
Wider is 40 . Actually about 21 per side on my used set.
I know this is an old thread, but I just saw your postUsually 40 at the heel up to 50 at the tip. They suck to sharpen for a while in that case.
If you have a drop point, the steel gets thicker at the belly. The angle has to get more obtuse in order to maintain a uniform bevel width for aesthetic reasons.I know this is an old thread, but I just saw your postBellaBlades . I just acquired a Sebenza earlier this year. I noticed that on the flat/ towards the heel of the cutting edge its set at 20 DPS. But on the belly/ toward the tip, the bevel seems to be set at 25 dps.
Seems to line up with your findings. Is this typical with CRK knives?
Makes it a pain in the ass to sharpen!
Ah! That makes sense. In that case, if I were to sharpen at a constant 20 degree angle with a fixed system, I would have a fat bellow and skinny straight/ flat.If you have a drop point, the steel gets thicker at the belly. The angle has to get more obtuse in order to maintain a uniform bevel width for aesthetic reasons.
With a fixed angle system, you can overcome the problem by clamping the knife a certain way. I keep the approximate factory bevel, including the uniform bevel width. What system do you use?Ah! That makes sense. In that case, if I were to sharpen at a constant 20 degree angle with a fixed system, I would have a fat bellow and skinny straight/ flat.
So I guess you really need to use a sharp maker or free hand a sebenza it sounds like?
