There's always chat about knife sizes and some people have no idea how big a Sebenza is beside a Mnandi or what any of them look like in hand.
EDIT: Please also see post 21 below for new information on the differences between the Regular, Classic & 21 model Sebenza.
So I have taken a few picture to show this plus I've taken some measurements. The earlier versions started with an ATS-34 steel blade heat treated to a hardness of 58-60 RC and followed with a BG-42 steel blade heat treated to a hardness of 60-61 RC, which included the now famous flat ground models, and the most recent Chris Reeve folding knives have a hollow ground S30V steel blade, heat treated to a hardness of 58-59 RC. Blades are also available in various Damascus patterns with the steel usually coming from Devon Thomas. The handles are made from 6A14V Titanium. They are all assembled with Allen key headed screws and can be easily stripped and rebuilt. Here is a link to just that,
http://www.chrisreeve.com/sebenzaclean.htm
Here is the FAQ from the company which cover all the usual queries,
http://www.chrisreeve.com/faq.htm
The large Sebenza:
3.625" (92mm) blade and overall length of 8.335" (212mm) 0.125" (3.175mm) blade thickness.
The small Sebenza:
2.94" (75mm) blade and overall length of 6.875" (175mm) 0.125" (3.175mm) blade thickness.
The Mnandi:
2.75" (69.5mm) blade and overall length of 6.375" (161mm) 0.090" (2.30mm) blade thickness.
All three together. From top, Mnandi. Middle is the small Sebenza and bottom is the large Sebenza,
All three open with a measuring ruler,
All three in hand,
Here's the various parts and fully disassembled pictures of a Sebenza & Mnandi. My list may not have the proper technical names for these items - I have just named them as such to help you identify them during assembly.
Sebenza (parts shown from top to bottom are)
- Front side handle
- Large washer - front side
- Small washer - rear side, smaller due to the lock bar travel.
- 3 sets of bolts and screws which are identical
- Largest spacer is the rear backspacer
- Medium spacer is the pivot bushing
- Smallest spacer is the bladestop spacer
- Small roundhead screw is for the clip shown beside it
- Allen key
- At the bottom is the rear side handle with blade to the right.
Mnandi (parts shown from top to bottom are)
Front side handle
Top row (l~r)
- Pivot bolt
- Rear backspacer
- Pivot bushing
- Bladestop spacer
- Pivot screw cap
Bottom row (l~r)
- Rear bolt
- Pivot screw
- Rear backspacer screw
- Small washer - rear side, due to lock bar travel
Clip
Allen Key
Mark
The large Sebenza:
The small Sebenza:
The Mnandi:
All three in hand,
- Front side handle
- Allen key
Front side handle
Top row (l~r)
- Pivot bolt
- Rear backspacer
- Pivot bushing
- Bladestop spacer
- Pivot screw cap
Bottom row (l~r)
- Rear bolt
- Pivot screw
Clip
Allen Key
Mark
