SwissHeritageCo
- Jan 8, 2021
So... I've been using solid brass "traditional" rivets on a new dangler design of mine to make it more bombproof, but also to be able to post through 3 thick layers of leather. The problem I'm running into is that my rivet setter is dual use, it has a hole on one side to set the washer and the shallow concave dome on the other side to peen the cut post. It seems every time I'm peening I'm marking up the leather because of the width of the setting tool itself. A fatal design flaw in my opinion.
I went searching for a rivet setting set where the functions would be separate, but all I'm seeing is different versions of dual use setters? Surely I'm not the only one who's run into this problem. I'm after a clean uniform look so I don't want to use a ball peen hammer, the little concave dome functions perfect for my uses.
These seem to be the only set designed properly - https://www.rmleathersupply.com/products/douglas-rivet-setter-domer?_pos=2&_sid=5b707b17f&_ss=r but I am not looking to spend $150 to be able simply set a rivet properly.
Am I missing something here? A technique perhaps? Any insight would be appreciated.
