My wife and I own Atlas 1022 and 1033, respectively, and have had excellent luck with them. Being one of the top-rated models of snowshoes for several years helped with our decision as well. While I appreciate the asthetics of wooden showshoes, we went with the newer materials for the reasons mentioned above. We try to get up north at least several times a year to use them, and actually shuffled around the neighborhood several times during and after last year's snowstorm here in Michigan. Great fun, and great for the looks we got.
Lee, if you can walk and chew gum, basically, you can snowshoe. Your gait is a bit wider, and your hips will get a better workout for it. It just takes a bit of getting used to. Like stepping high enough or "long" enough over things to clear the shoe, or not putting both feet to close together when standing still, and then trying to take a step, leading off with the one snowshoe that the
other one is standing on. LOL, I ate snow a couple of times on crazy "DOH!" moves like that.
One thing I was recommended while initially shopping for aluminum-frame models is to look for the one-piece welded frames as opposed to those with the plastic connector plugs at the tails, as the plastic may become brittle enough in extreme cold to break if heavily torqued, ie. a fall or other off-kilter maneuver such as stepping incorrectly across a rock or log. Don't know if how much of an issue this may really be, but the situation should be considered. Regardless, I've always included hose clamps and two pieces of similar-diameter aluminum tube split lengthwise in my snowshoeing kit. In the event of any sort of tube break, with my Leatherman and Sebenza, I can smooth out ragged tube ends, whittle down a branch for a tube connector plug, and clamp the frame back together. Large zip-ties and/or old mountain bike tow-straps would probably fix about any binding problem that occurs. While the chances of such an event occurring are very low indeed, most of us who frequent this forum
are on this forum because we tend to plan for or anticipate such contingencies, so I just thought I'd mention this.
Greg, what's your track record been with the Atlas brands over the years, anything to report at all? Ours have been perfect, but we don't put he hard use and miles on them like your gang does.
Don LeHue
The pen is mightier than the sword...outside of arm's reach. Modify radius accordingly for rifle.
[This message has been edited by DonL (edited 01-12-2000).]
