I rounded the edge with a diamond film to break the cornerI was also looking at different chisels for this lately. Could you show us the tip/point of yours?
Thanks, very helpful of you!I rounded the edge with a diamond film to break the corner
That one looks to pointy for my preferenceThanks, very helpful of you!
So, a flat chisel with rounded edges.
I was also looking at a pointed one, thinking of rounding of the tip and try that. This one is 20 mm at the shaft.
Yes. It has to be harder than the steel
The chisel I’m using is in the 70’s as I recall
I don’t think u can get steel that high of hardness
No. Never cracked a blade this wayHas anyone noticed that using this technique causes weakening or cracking in blades?
I've noticed after some use that the tap point is dull. Will any type of carbide work? I can get a tungsten carbide rod blank pretty cheap.Out of the tons of blades I have straightened only one has cracked and that was a .0395 ulu made out of aebl. It was warped so bad that the amount of peening it needed exceeded what the tip could take.
As to using HSS I never got good life out of them. I switched to carbide and never looked back. I now use a sewing machine that I modified into a blade peening machine. With the volume of blades I process I could not keep up doing it by hand.
I am in Europe too and struggle to find a carbide ball or chisel to build a staightening hammer.Yes that is a good video.
Just ordered a flat head wolfram carbide chisel (made for hand carving stone) with 10 mm wide head, 170 mm OAL, from a reputable German brand (I'm in Europe). I will also round off the corners. Interested to give this a go.
Could you tell me what you ordered and where?
Thanks
Dan
Cheap solution - The largest masonry drill bit with carbide tip you can get. Preferbly over 14mm. Round of the tip with a diamond stone or a busted 120 ceramic belt.I am in Europe too and struggle to find a carbide ball or chisel to build a staightening hammer.
Thanks
Dan
