Originally posted by 7Cain
I don't think that having a 65 Rockwell tang pin would be any problem at all (I certainly don't think it would shatter). Even the bearing steel you mentioned is pretty hard stuff Tony.
Retempering those pins to be a little softer than the blade isn't an issue if you knew the steel composition (which is something you'll never find from a nail). Obiviously, making your own tang pin would be the best since you then are picking your own steel and controlling the pin size. Needle bearing sounded like a good choice because you can get them made up to your specs by lots of little machine shops.
The problem lies in the relationship between the tang pin on the blade and the tang pin cups on the handles.
Yes, but you can always make the handles softer than the tang pin. So in terms of hardness, the hardest would be the blade, then tang pin, and last the handle. Even with a softer handle, you'll still have to deal with the impact stress of the handle hitting the tang pin, and the tang pin transferring that stress to the blade. A softer tang pin will cushion that stress a bit to avoid stressing the blade.
By the way, I fixed my squashed tang pin by rotating it in the tang about 25 degrees. Open lockup is now tighter than it was when I first got it.
OK, here's where I have a problem with the way BM makes the tang pins. If you are able to rotate it, then it's not 100% tight against the blade, and there's a minute gap between the tang pin and the blade. The will cause the tang pin to bounce against the blade's tang pin hole. In my books, that's a bad design. Using the freezing method, you'll get a as perfect to 360 degree mating, with little to no gaps as possible, for maxium friction lockup, for all 3 axis (no sliding up or down, no rotation, and no wobble). Plus there would be no need to peen. Peening the tang pin into the blade, ala the Jag, causes too many issues with the handle relationship you and Eric were referring to.
OH AND HEY TONY, LOOK AT OUR NUMBER OF POSTS!!! WE'RE TIED
Not anymore.... besides, you've had a 3 month head start.. OK, so I'm a blabbermouth...
Tony
