BluntCut MetalWorks
- Apr 28, 2012
Test 1095 & O1 steels impact/shock load. Video might be interesting/entertaining or painful... obviously I don't have skills nor stamina using axes
Yep, off a public trail near a junction thus ppl passing by. In dry season, I walk deeper into woods/almost-forest but too muddy this time of year.Looks like they held up well.
Sorry to be nosy, but I’m kinda curious as to why you were chopping those trees up. It looked like you were in a public park and they were off-trail…?
Your time & honesty(takes courage nowadays) are well appreciated.houla! such a pain to see! i would never chop a tree in shorts and no iron sock (sorry i don't know the real name for it)(even thought i spend 2 hours bucking with trousers only this morning, but i am a bit seasoned and i don't allways do what i preach)
to axes:
first one ,apart from beeing an ugly tinkering, is too short for the purpose you put it in . i can see once or twice your leg too close and in the way... it is rather made for chopping on a block using thick part of the tree, to do so.
big one : some same tinkering, and plastic handle; the kind i like on a splitting maul but hate on an axe! to much vibrations . you hit from above ;fine; but you end plowing as you came for bucking! it is better to chop from the oposite side of the log towards you. and obviously placing your feet paralel to the cut.
the wood used is one of good will, as i use to say ,don't try on a harder one.
you say steel is 63 hrc , fine, but it just needs basically to be harder than wood.
you worked on eucaliptus and beeing in shorts i guess you are from down under.
to far from Italy, France or Spain and Portugal to get real thin axes on cheap to work with and see a world of difference!
is that to much honesty?
Ok - just FYI - that might not be legal unless you got permission.Yep, off a public trail near a junction thus ppl passing by. In dry season, I walk deeper into woods/almost-forest but too muddy this time of year.
I'm pretty sure We can clean out fallen trees here in my area. It helps prevent fires spreadingOk - just FYI - that might not be legal unless you got permission.
Generally folks want parks to be relatively natural and undisturbed, and fallen trees are generally a protected feature of the park unless you’re on a volunteer trail crew, etc. and targeting trees that are dangerous or blocking trails.
Not trying to tell you what to do, I just don’t want you to get in trouble unexpectedly.
Thanks.Ok - just FYI - that might not be legal unless you got permission.
Inferred via Rockwell Hardness Tester reading of a 1095 2.5mm thick charpy impact specimen, that was hardened along with this axe bit (which welded to axe head later on). 1095 is a shallow hardening steel (aka low hardenability) so for the quenchant I used - it only fully hardened up to 4mm thick, thus sort of differential hardened. O1 is an oil hardening steel, so easy to full harden 10mm thick axe bit (shown bit only 8mm but I do have 10mm thick bit at 63.5rc). In the past I used interrupted super-quench to fully harden all shallow hardening steels, W2 included. I need repeatability, where super quench brings high variances of result.How did you test the hardness? RC63 is too hard for an axe. The O1 might hold up.
