- Sep 29, 2015
Jeff, like Me2 mentioned, normalizing technically is one cycle, not several. He is just trying to separate the correct terminology for future reference by others. Normalizing is done usually at least 100-150F above critical, one cycle, with an air cool. It is done to break up carbides that might have clumped together during previous forging/rolling, and to distribute them evenly. It is a one time deal. No need to "normalize" more than once, if it was done correctly.
Then we do "thermal cycles". This is really more about aus grain refinement than anything, putting more aus grain in a given area/volume, hence making them smaller. This is done usually around the critical temp, slightly above it, at it, and slightly below it. I suppose that ANY heat operation could "technically" be called a "thermal cycle", but for us knife makers, we understand that term to be limited to cycles at/around critical for aus grain refinement. After "thermal cycling" has been done, if no further machining needs to be done on the work piece, go straight to hardening. I asked Kevin what the best condition a steel could be in for hardening, he said either fine pearlite or upper bainite. Not a spheroidized structure, not a martensitic structure. That means that after the air cool is done on your final thermal cycle, you should have fine pearlite, one of the best matrices to harden from. I won't get into bainite, as that has a specific HT to develop.
Below "thermal cycle" temps is annealing temps ~1300s. For high carbon steels it is usually always best to spheroidize anneal if any further machining needs to be done. There will be no change over to austenite at these temps (below 1350f), so technically not much in the way of grain refinement here, mainly to soften things up. The mill that serves Aldo uses heavy spheroidizing on some of the steels, like 52100, and it is done at these temps for extended periods of time, hours upon hours from what I understand, with a very very slow drop in temp from sub critical on down to 900F or so. This causes large spheroidized carbides. Butter soft on tooling, but not so great to harden from.
Below annealing temps is stress relief temps ~1200s. Interestingly, if you take a martensitic blade (as quenched from critical) and "temper" at ~1200-1250F for a couple hours, you will fine spheroidize the steel for excellent machinability. This is also an excellent state to harden from, as it is extremely fine spheroidized, and does not need normalizing or extensive soak times to put the carbides back into solution.
Below ~1200s you get into the secondary hardening temps of tempering, post quench of course.
Your "assumption" that the subcritical temps you are using is what gets your W2 sample to harden properly is not correct at all. AAMOF, you do NOT need to do ANY subcritical temps to get a steel to harden after normalizing. Your test may seem to support your theory, but it is not correct by any means. Not meaning to hammer at you, just saying. Your 3rd sentence in the post above....again, no, subcritical cycling has nothing at all to do with normalizing. It is a completely separate operation for completely different purposes.
Thank you very much for that very informative post Stuart because I couldnt find anywhere on any posting what the difference between normalizing and thermal cycling was and I apologize if I have been using the words interchangeably because I thought they were referring to the same thing and now because of your very detailed explanation I know better.
Obviously you know much more than I and I appreciate you taking the time to explain to me this topic because I want to learn and make the best knife I can. And I do not dispute or challenge any of your information on this post and appreciate finally I understand exactly what the different temperatures and cycles do.
With that being said though it isnt an assumption on my part that the addition of subcritical temps is what is getting my W-2 sample to harden properly its simply an observation. I am not disputing your information I am just saying my tests seem to show that I cannot harden W-2 unless I have subcritical temperature cycles and just normalizing alone wont give me hardenable steel.
I have done two tests now without subcritical cycles and without them I cannot get my samples to harden properly. Honestly I dont know how to reconcile the fact theory says that I do not need any subcritical temps to get a steel to harden when from several tests now it is evident that I do. Maybe this is just a very strange batch of W-2 but despite all the theory that is the reality.
I have done so many tests I even lose track of what I have done and have to refer to my notes to understand where I really am but in case it is confusing I do actually have two successful heat treats to give me consistently hard W-2 in the 66 to 67 range.
I can get in that range by either using 1650°F, 1350°F and 1250°F and not quenching or using 1650°F, 1550°F, 1450°F, 1350°F and 1250°F and quenching after every temperature. And I know that makes absolutely no sense but they are both systems that work consistently so I guess I can use this steel now. And I have been unable to get hard results without adding the sub-critical 1350F and 1250F cycles.
Basically I am just playing around now trying to see if I can get in the 68 ½ range which seems to be the maximum and also I am really curious about what makes this steel vary so much. So I appreciate your input because I understand much better what should happen but what is perplexing is that it doesnt seem to be with this steel. But really thank you again for that post because it explained exactly what I have been looking for and been unable to find so I really appreciate the input.
