Still been practicing knifenut's technique of lifting the handle to maintain the angle around the belly. Continue to be impressed with the accuracy. I've been using an EP for 3-4 years and only got into trying to improve my free hand ability in the past few months. So, instead of having flat bevels on all my knives they all have convex bevels now. What I have done in the past is try to maintain a flat bevel (created with the EP) on bench stones. For 2 or 3 strokes I can "feel" when the bevel is flat on the stone. After that I've rounded the bevel enough that I can't feel any flat portion on the bevel any more. When the bevel is flat I can see any imperfection in angle consistancy just by looking at how much I am rounding the bevel. Since they are all convex now I have used a marker to see where the bevel is touching the stone. Using knifenut's technique I'm seeing emprovement in keeping the removed marker line consistant in location on the bevel around the belly. Not perfect (never will be), but it's getting better with practice. So far the only thing I have done is try to maintain the same convex bevels on the knives. I haven't tried to create a bevel as flat as I can yet. In one of knifenut's posts I think I remember him saying the knife sort of rides on the bevel during the stroke. Since the only knives I've worked on have convex bevels I haven't had this feeling at all. I think I may need to create a flat bevel with the EP then try to maintain the same angle free hand. I have done this in the past and failed. But now that I'm using this "lift the handle" technique I need to do it again. I just want to see if I can "feel" the edge angle on a flat bevel as I go around the belly. Maintaining the angle on a straight section of a knife edge is easier. Just find the flat spot, lock your wrists and go slow. When going around the belly you need to start raising the handle I have a tendency to change the angle unintentionally. The angle is changed by spinning the knife handle in my hand/fingers. This is a no-no. So far I have been spinning the handle intentionally since I have been working on convex bevels.
The key to improve any skill is practicing. Don't know how often I have sharpened a sharp knife.
On knives I don't care about how much steel I remove I just mark the edge and practice maintaining the same angle by watching where the marker is removed. I use a very fine grit stone when just practicing so very little steel is removed but I still get the practice.
This thread has been great for me because after learning (not mastering) of one technique to control the angle I now have another one to use. In addition to having an option of technique to use I also seem to have a better understanding of maintaining the edge angle. I don't know how to expalin what I mean so I'm not going to try. I was practicing with a knife last night and as I rounded the belly and getting all the way to the tip I was not touching the edge apex for the last 3/16" of the edge. I was hitting the apex around the belly except for this one spot. At first I was thinking my angle control was flawed at that spot for some reason. That meant I needed to do something different in how I was holding the knife and/or moving my hands. The only way to hit the apex in this one spot would be to raise the angle a tiny bit. I know this is a no-no but I couldn't think of any other way to get to the apex. THEN IT HIT ME! Maybe there was nothing wrong with my technique! MAYBE I just needed to remove more steel on the bevel at the same angle I was trying to maintain until the edge apex was on the stone. Wow, could it be that simple? This made more sense than changing the angle just to hit the apex since maintaining the same angle is the goal. I know (well, believe) that is the answer but I haven't done it yet. It was getting late and my head was nodding.
One sharpening tradition I like to keep is not to fall asleep when working with knives allowing my head to fall down onto the extrememly sharp edge.
I do enough damage to my face when shaving.
Thanks again knifenut for a great thread. You do know (don't you???) that some people charge for this knowledge??? I have considered buying Murray Carter's DVDs but never did. I'm sure they are FULL of great info but so is this thread. So thanks for this because I can now use the $70 or so to buy shoes for my 10 starving kids.
Jack
