- Aug 29, 2010
Jeebus, give a guy time to think...
OK, cereally, I was thinking about this late last night. RMK (the other RMK), solders screws (maybe it's pins) to their end plates and throws 'em in a bin. When an order comes for an end plate, NS or Brass, they grab one, screw or epoxy it in, then form it to the handle end shape. That's my understanding, anyway. So, the question becomes, have you looked into this process and given it thought as to having stock on hand? Bin o'this, bin o'that, and so on...
That's a "more than one way to skin a cat" kind of thing I think. I'm guessing with their tang construction, they thread the tang end, or attach a threaded rod to the end of the tang. Then either thread the end plates on, or thread a nut over it, or both.
Here's an example of ours.
Seems to me I've seen a picture of their tangs, I'll try to find it.
Edit, found it.
Randalls tang constuction:
The way I attach the end plates keeps me from having to thread the tang and worry about things beng perfectly straight so the handle material matches up, or so the nut is flush with the plate when everything anugs up. It does make me slot and fit the end plate so the tang can get peened, but it will always be flush.
I don't know if any of that made sense lol. I think the answer right now is it's six of one, half a dozen of the other. I'll take a look at the process and see what I can do to smooth things up. With the model that I'm gonna be working on along with the Bowies, I'll be able to pre cut spacers, guards and end plates, and only have to do some final fitting for the individual blade. Three blade profiles, identical tangs
When we did the keys for the Corsairs, I made a hardened guide to help slot the scales out for the key inserts. It's come in handy for fitting guards and end plates. I super glue it onto the material, use it like a drill guide, and it gives me a good starting point to fit things up.
