- May 29, 2004
First off a disclaimer: This isn’t technically about a Busse. I’m posting here because the question has to do with INFI:
I love the balance and design of this knife. It’s very similar in feel to my Swamprat Taliwhacker, however it doesn’t seem to bite into wood as well, even though it’s heavier.
I’ve thinned the edge of the Tali to about 15 dps on an Edge-Pro. I’ve only knocked the shoulders off of the Scrapyard AD and so the actual edge is still probably around 20+ dps.
I’ve been admiring the work of Josh (REK) and others who have thinned the blades on Busses/Bussekin and was thinking about that for this blade. It’s fairly thin already (.21” stock), but I recon it can go thinner - how thin would you go?
Or, should I just spend another hour on the Edge-Pro and try it out before sending my knife away?
OR, should I try stripping the primary grind and thinning the edge?
FYI I would be using this as a backpacking/hiking knife that might be chopping hard wood occasionally (trail clearing mostly) so I want an edge thick enough to hold up to this. No batoning through metal or large logs, etc. for this one…
Thanks!
Thanks!
