- Mar 11, 2011
I've been wanting to get a little AAA flashlight, and settled for the ThruNite Ti3. About $20. Here's the specs from the Thrunite site:
Key Features
⦁ LED: Cree XP-G2 R5 LED with a lifespan of
20+years of run time.
⦁ Battery: 1 AAA battery
⦁ Dimension: 70mm(length)*14mm(head diameter)
⦁ Weight: 12 gram without battery.
⦁ Reflector: OP Reflector
⦁ Aircraft quality aluminum body structure.
⦁ Premium Type III hard anodized anti-abrasive finish.
⦁ Waterproof to IPX-8 standard.
⦁ Convenient twist switch.
⦁ Output and run time:
Firefly: 0.04 Lm(115h), Low: 12 Lm(6.3h), High: 120Lm(0.5h), Strobe:120Lm(1 hour)
⦁ One handed operation.
Operation
Turn on /off
Easily twist the head to turn on / off the light. Tighten the head for on and loosen for off.
Change modes
When the light is on, turn off the light and then turn on in 2 seconds to change output mode.
Memory function
Keep the light off between 2 to 10 seconds and then turn on, the output mode will keep the same as your last use.
Over 10 seconds and then turn on, the output will get back to firefly.
Hidden strobe
Cycle the Change modes for 6 times to activate hidden strobe mode(120Lm,13Hz).
In sleeve:
Out. Came in a tin:
Instructions:
Key chain/clip:
Came with a clip:
Logos:
Next to my AA Fenix LD10:
Hard to believe it puts out 120 lumen:
Next to a Bic lighter:
Here's a video review of it someone did:
[video=youtube;WEi59r3M9nM]https://www.youtube.com/watch?v=WEi59r3M9nM[/video]
Cool little light, should come in handy. Thanks for looking.
Key Features
Operation
Turn on /off
Change modes
Memory function
Hidden strobe
In sleeve:
Out. Came in a tin:
Instructions:
Key chain/clip:
Came with a clip:
Logos:
