Hello,
As for Myself and my Knives i kind of even Refer to my own grind as a "UTILITY GRIND"
my theory is that a blade has to Be Ground and taken as a Whole object not broken into segments as to type of finish, so i consider the Finish of a Blade and the Grind of a blade as one in the same.
I consider a UTILITY GRIND in the same sence
i do when i take a Flat ground blade to
150 finish grit,then Scotch brite belt,bead blast, and Hard coat finish, although i call it a Combat utility grade Finish.
i dont think a Flat ground Scotch brit finished Blade should be finished to any less a degree of accuracy than if it was a mirror polished blade,its degree of formalized finish is i think what Denotes a Utility/User Grind from a more Collector type Grind/finish.
Either that or i am just tired and spent the last 5 minutes typing without reason at my keyboard <shrug> nite all!
Allen
[This message has been edited by Allen Blade (edited 02-23-2000).]
