what about the paper stones on the buck ecolite folders?
The very surface of canvas and linen micarta may absorb a very small amount of solvent in the exposed fibers. STR did some solvent and fuel soak tests with micarta handles and found that once that little bit of fuel burns off the surface there's no affect to the material.
http://www.bladeforums.com/forums/showthread.php?t=407828
*edit* Wow this is an ancient thread
Carbon fiber gets fatigued and causes sudden catastrophic failure of aircraft. Am I right?
I am suspicious of it.
Then again, knife handles are a totally different application from wing spars.
Micarta I believe is made from linen, paper, canvas, etc. Some kind of epoxy is used too. G10 I believe is an epoxy and fiberglass resin compressed under tremendous force. I may be wrong on this, but AI think it is pretty close. The smoothness of Micarta will vary with type and finish. Canvas with a low grit finish will feel like a cat tongue. Paper is usually very smooth. I like Micarta, because that is what is on the Spyderco Viele. I actually never thought Carbon Fiber scales were that great. JMO.
I am thinking of giving G10 a try on my next purchase, probably a Bark River Bravo 1.25; that is a sweet little fixed blade!
Hardly. It is strong for its weight and relatively inert, but has its issues too. It is relatively soft and scratches easily. And a nick or scratch in titanium will often lean to microfractures that propagate all the way thru the piece.The unquestioned nominee is Titanium. When the world ends it will still be functional.
