Bobby Branton
Moderator
- Dec 12, 1998
This is a work in progress thread and I will document the steps I use in making a blade for my Transition folder.
Using my MasterCam program, I will draw a fixture to fit my parts on. I then use the CNC mill to spot my tie down holes and make a skim cut so that I will know how to position my blade coupon so that I can make a master coupon in case I want to make more blades.
I then drill and tap the hole for a 4-40 screw and screw down my coupon to the fixture.
I then execute the program to make the profile cut as well as the cut for the blade stop pin.
Here are the finished parts. I do this for the handles also. All drilling, reaming and counterboring is done on the drill press. I grind off the bump on the tip of the blade when done.
