The Xiaomi Dreame V9 vacuum cleaner weighs only 1.5kg, so that you can handle it easily and even turn it into a handheld vacuum when you need it. For ease of cleaning, the installation position of important components are optimized, and the center of gravity is moved backward, make it lighter and more flexible when pushing, pulling and lifting.
Product Features:
● Space3.0 brushless digital motor, spins up to 100,000rpm per minute, generates 120AW and 20,000Pa powerful suction.
● High effective five-stages HEPA filtration, filters out dust as small as 0.3 microns and 99.99% of allergens.
● Unique SmartCool3.0 air-cooling system, ensures optimal motor operation and directs part of the airflow to the battery to accelerate heat dissipation and improve endurance.
● Samsung imported lithium battery pack, energy-saving mode operation about 60 minutes, can clean 380 square meters areas.
● Soft roller cleaner head for all kind of dirt, dust, and hair from the floors, combing structure avoids the hair winding around the soft roller.
● Mites cleaner head built-in independent motor to remove the dead skin and invisible mites from mattress.
● Dusting brush used to gently removes dust from screens and hard surfaces, and the crevice tool designed for precise cleaning around edges and narrow gaps.
● Hygienic bin emptying, no need to touch the dirt, just press the button to release it.
● Wall-mounted charging dock equipped with storage and charging, takes only 3.5 hours to charge once.
Keep your house clean and free of mites with the dust brush for surfaces, clean the most difficult corners with the crack tool. Then empty the dust container, releasing it with a button in the bin, Xiaomi Dreame V9 is what you need: https://gearvita.com/xiaomi-dreame-v9-vacuum-cleaner.html
Hot sale Xiaomi products:
mi band 4
xiaomi redmi airdots
Product Features:
mi band 4
