Xiaomi Duka LS-P laser range finder features only two buttons, but its functionality is wider than that of many similar. The list of functions includes single measurement, continuous measurement, angle measurement, area measurement, as well as volume measurement - all this with one button. The measurement process is carried out by emitting a laser beam, reflecting it from the obstacle, and simultaneously scanning the reflected beam with an optoelector sensor.
Product Features:
● Wide measuring range up to 40m with a high accuracy up to ± 2mm.
● 200mAh large capacity lithium battery, enough for 3500 measurements, charging via microUSB connector.
● Switchable among meter (m), inch (in), feet (ft), convenient to read the measuring results.
● Light to 28g, small volume, can be carried in the pocket.
● The case of the device is made of an aluminum-magnesium alloy and ABS plastic, has anti-corrosion properties.
● Large LCD with backlight, the data can be seen clearly even in low-light conditions.
It is a useful gadget that is widely used in interior decoration, indoor design, construction field: https://gearvita.com/xiaomi-duka-ls-p-laser-range-finder.html
Hot sale Xiaomi products:
xiaomi inface sonic clean
xiaomi mi 9t 64gb
Product Features:
xiaomi mi 9t 64gb
