rhino said:Okay you experts and other helpful types ...
I just had a problem with my Zippo. I was outside clearing snow (it's above 20F and sunny) and I wanted to use it to help free a frozen lock. I couldn't get it to light! I thought it might be dry, so I added a little fuel, but then it still wouldn't work and eventually I couldn't even get a spark. When I came inside and held it in my hands for a little while, it started working like it always does.
So ... any ideas what the problem may have been? Could some snow or moisture in the air have frozen between the striker wheel and the flint or something? Why wouldn't it light when I had sparks and I knew I had fuel?
The reason I have a Zippo is so it will work in the cold and other adverse conditions!
mrd74 said:Replace the insides with a Z-Plus Butane insert....supposed to be able to melt a penny and windproof to0.
omaha-beenglockin said:My Zippo sits negleted----and I carry multiple Bic's------carried in pants pocket my Zippo gives me rashes----the Bic's don't-----just that simple.
Unless I've been doing something wrong all these years???
Mike Hull said:Sounds like it might have been flooded. If it happens again, blow on the wick and strike again. Do you keep the striker wheel clean etc.? A good brushing occasionally will keep a built up of flint residue from preventing a solid strike on the flint. If that happens, or the striker wheel gets wet it may show sparking but it's not throwing enough to light.
