ZMI LPB02 flashlight is equipped with aluminum alloy body, which is durable and supports IPX6 waterproof. Built-in LG high-density lithium-ion 5000mAh battery, it can meet 3600 minutes of lighting and is also a power bank that can be carried on the plane, supports two-way fast charge. It also supports 5 levels of light intensity adjustment, and can be used as a small desk lamp with the included soft mask in the low level mode.
Product Features:
● Minimalist aluminum body, lightweight and portable, with round hole dot matrix anti-slip design.
● Imported lamp beads, with a service life of 10,000 hours and 500 lumens, and the longest range can reach 110m.
● 5000mAh large capacity battery, can meet 3600 minutes/60 hours of lighting.
● Two-way fast charge, USB-C input port and USB-A output port, achieves up to 12W output.
● IPX6 waterproof, can be used normally outdoors even in heavy rain or worse weather.
● 5 level modes adjustment, matches with the soft light mask to make the light more soft.
● In an emergency, the SOS mode can be awakened with three clicks of the button, and a flashing distress signal will be sent.
● High-precision resistance capacitance device, advanced circuit chip, can easily deal with various abnormal conditions such as overcharge, over-discharge, high temperature and short circuit.
You can also match smart gadgets such as Mijia portable fan to bring you more fun: https://gearvita.com/xiaomi-zmi-lpb02-5000mah-power-bank-flashlight.html
Hot sale products:
xiaomi pro wifi amplifier
honor band 5
Product Features:
Hot sale products:
honor band 5
