- Jul 28, 2020
I love working with 1095, but getting the HT right is absolutely necessary.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I was wondering about this too. Maybe ranch work involves cutting hundreds of feet of sand paper? Maybe this ranch uses the sand paper instead of wire for fencing material, if so I wouldn't blame them. Cows can go right through fences you think would 100% stop them, so maybe the sandpaper chafes them so that they think twice next time?I see that you haven't been back since Sunday (four days ago now), but hopefully you drop back by, because I'm curious about a couple of things:
1. What is your testing regiment that you're using in order to ascertain the HRC of all of these different steels?
2. What are you doing "on the ranch" that causes you to need to sharpen a knife in 1095 "six times a day"?
I'd appreciate some more info on these, thanks!![]()
Very informative. What do knife and steel do you generally use under these conditions?Well since he hasn’t answered yet and the previous comment let me enlighten you. On a farm and ranch we have some very abrasive stuff. In the winter when snow is covering the grass we feed as many as 10 large round bales every day . The poly twine is tough stuff and it is full of abrasive sand and other nasty stuff on the hay as well . Each bale has about 60 wraps of twine x number of bales that are pulled in tight so you are cutting twine and hay using a push cut. Not only hay bales but feed sacks, rope, bags of minerals, plastic buckets, nylon ties and many other materials. So yes it is similar to cutting sand paper and requires a tough wear resistance steel.
My preferred knife for the ranch is 20cv. It stays with it a long time.Very informative. What do knife and steel do you generally use under these conditions?
All that sounds pretty tough. I wonder what people on farms used a hundred years ago? I'm guessing the richer farmers used 3V or Magnacut*.
Also, if you're cutting a bunch of plastic buckets every day, then maybe it's time to look at something a bit more sturdy than a knife.
* The joke being that clearly, work got done on farms back then without the aid of supersteels.
I haven't use 20cv under your conditions, but when I have used it, I found it to be great stainless that hold an edge for a good long time.My preferred knife for the ranch is 20cv. It stays with it a long time.
Back then they didn’t have poly twine or large round bales. The hay was usually hauled loose in a wagon, sled or barge and they tossed the hay with a pitch fork. Things are much different now and require some more better materials. When you work a full time job and operate a ranch you can’t waste time on the little stuff. Get it done as efficiently as possible.All that sounds pretty tough. I wonder what people on farms used a hundred years ago? I'm guessing the richer farmers used 3V or Magnacut*.
Your sarcasm fell flat as it’s very obvious you have no clue what you are talking about. Nice try tho.All that sounds pretty tough. I wonder what people on farms used a hundred years ago? I'm guessing the richer farmers used 3V or Magnacut*.
Sisal Twine vs Poly Twine (Polypropylene) was used when I was a boy. The sisal cut easier than the poly of today, but still same issue of the sisal rope/twine becoming embedded with abrasives (sand, dirt, etc.) which are major cause of apex dulling & damage.I was thinking the same thing, but then thought that perhaps back then poly twine and plastic weren't the enemy, and it was something more "natural" that was an easier match for ordinary carbon steel.
My feelings aren’t that fragile. You might try staying on topic and steer clear of smart talk. 100s of acers? We operate over 2000 and we are on the small side. We have had as many as 500 head of cows and that’s a small time in this reagion. Again you’re out of your element.Your feelings seem hurt. So, what I'm hearing is, two specific items have been added to the "Things a Rancher Needs to Cut" list, and that's why 1095 can't get it done (for some reason) in 2022. Got it.
But hey, good for you.
P.S. I have family who have been ranchers, and they made do. Guess they must not have had any poly-twine or hay bails laying around on the hundreds of acres they managed. Huh, learn something new every day.
Yes, on the "like carpet installers" type knife.So, in other words, you'd probably want to use something like carpet installers, and warehouse workers who work with cardboard all day use, and go with some type of box-cutter affair with replaceable blades?
