We would all have to wonder about the accuracies vs Cliff wanting to show himself to be right.
... you've decided it's OK to compromise people who trusted you in doing it.
I will also caution you from calling me a liar ever again, there is no place on any forum for that.
The restrictions that have Cliff upset are the fact that I shut him down from being involved with the testing...
I do not feel bad about using this average.
However, Sandvik claims that they eliminate all primary carbide in the forging process in all alloys ...
... and the micrographs for carbon steels in Landes' book don't look any finer than 1 micron, they look larger to me.
When it's thinned down to approximately 0.012", no, it won't cut like 1095 thinned down to 0.0004", but it will handle most every-day tasks without the person holding the knife having to take care beyond basic safety.
Are there heat-treatment recipes which would uniformly bring 13C26 to a higher level of hardness without a high level of surprizes?
That is always the problem, restrictions in cutting ability for the sake of durability or range of work.
This is a well known steel, there really should not be any clause for experimentation in the discussion. Now as to the effort, you can see Landes heat treatment. Aside from the triple quenching, it isn't overly complicated and this is just his perfectionism showing. This isn't gaining a huge amount of hardness, he is just attempting to minimize as much austenite as he can. Now he is clear you can push past 63 to 65 HRC with the same heat treatment - but this is likely custom only as he generally states production loses about 2 HRC due to less than ideal heating/cooling rates even with the right temperatues and cooling.
You'll see restrictions on Johnston's knives, too.
Given that it's rare to see a production company run S30V above RC58 on a consistant basis ...
Will this decade close up with those same knives featuring a uniform hardness of RC63 and edge-thicknesses averaging 0.007"?
I'm thinking that the triple-quenching and expected loss of two points of hardness in large batches; escpecially the triple-quenching part; might keep RC63 13C26 knife blades out of the production market for a while.
Instead, you seek to impugne anyone involved, and regardless of your being able to see it for what it is, your writings in this thread display for ALL to see, unvarnished jealousy and a petty and vindictive character.
Steel arguments aside, I'm fascinated that vendors, either through ignorance or deliberate scheme, are selling knives that don't exist.
On all knives, they all have some durability limit. The really crappy thing is that you lose durability way faster than you gain cutting ability, as one is a linear gain and the other a cubic loss.
We need higher standards, you can buy $5 Mora's with higher hardness levels, not S30V, but actual knife steels. It is kind of sad that this makes an impact on the NA market, you won't see that impact at all overseas because the knives at 1/10 the price are superior. Nor of course they don't have flippers and such, but what are we talking about, steel or gadgets?
Given the overally nature of those knives, which clearly isn't a focus on a pure cutting tool (the handle says that strongly), you would expect the optimal edge thickness to be 0.010-0.020, with a proper edge angle of course, 10/15 or something similar.
The loss of +2 points is from 65 HRC, not 63 HRC. The triple quenching as noted is perfectionism, it is like mirror polishing a blade vs satin finishing it in that regard. Landes does it because he can, he is a high end custom maker. Then again, the actual time of the multiple tempering isn't that long and it is just two additional tempers. Most of the high carbide steels are mandated to have more than one temper when they are tempered hot as many of them are.
Are people understanding the reasons behind the performance and reclassifying steels based on a C/Cr ratio or is this just a particular brand getting acceptance? Would be interesting to see how it holds when compared to some high wear steels at the initial obtuse angles as it doesn't do well there for slicing aggression.
STeven,
What Bob Dozier does with D2 goes against the grain of the ASTM's recommendations. They say cryo is a very good thing for that steel and Bob says it's a work-around for a poor heat-treatment so far as blades are concerned. Bob's actions place him contrary to panels of published experts, but you know what? He's just as right for his choices as they are for theirs.
A lot of us here have been influenced by Cliff; not as much as you, of course; and we're all S-N and R-S for these Junkyard Dog II knives even though they're not Cliff's cup of tea in their current incarnations. That's fine by me. Along with cutting stuff, these knives must've been designed to please us Stampies while ticking off Cliff. Must be a duplex structure...
When you finally tire of asking the good doctor to ESAY, you might notice the both of youse agree a lot more on design and material aspects than you differ. For instance, neither of you would bring a tactical cake cutter to Thomas Welk's birthday party.
Triple quenching as we typically know it has to be modified for any real grain refinement with air hardening and stainless steels. You don't get any higher hardness using a triple quench, though.
Triple quenching as we typically know it ...
Cliff has tried to paint the picture of Thomas as a glad-handing sales servant of Satan, and this was bad enough, but he flat-out called Thomas a liar, and that is just not right.
Cliff doesn't leave his warren.
With blades, though, how much durability is needed for cutting?
My moras cost $9 and $13 US dollars ...
I think a folder of that class can handle 0.007" especially since we've both seen tantos and swords with 0.015" single-tempered 1095 edges handle worse.
There may be a reason why triple quenching is needed for AEB-L and 13C26 for certain applications ...
What intrigues me is that lower-carbide steels such as 13C26 and O1 and higher-carbide steels such as SG-2 and ZDP-189 fair better than S30V.
... we're all S-N and R-S for these Junkyard Dog II knives even though they're not Cliff's cup of tea in their current incarnations.
Whatchu talking about, DaveH?![]()
What I have said is that he, like all salemen, presents a biased argument. THis of course is reacted with shock and dismay by those which like to popogate the nonsense that those that sell products should be the ones used as sources of reference. Yes he lied in the above, several times, like I said look up the meaning of the word RESTRICTION.
I think the knives look fairly solid, clean grinds, handle looks fairly secure. That type of knife doesn't say "razor blade" to me though, and given the general design I don't see how the benefits of 13C26 are even close to optimal. But it isn't like the bajillion knives in S30V are all sensible either. There are a lot of crazy steel+ design choices, Satan isn't of course being them, just ignorance (well mainly fad).
-Cliff
Of course he has positive feedback, he sends out knives to people who are only openly positive about the knives and him in particular, restricts what they can do with them, restricts what they can say about them, and ignores the criticism and focuses only on the positive. If he actually wanted unbiased and meaningful feedback he would be acting in a totally different manner but that is not his goal. Lets not pretend it is a public service he is performing, he is here to promote Kershaw.
Actually I think you have it backwards. Some knifemakers make way too big a deal of grain size.I personally believe grain size is very important to the edge. Much of the problems and benefits blamed on carbide size I think is more to do with the grain size.
