I'd be hard pressed to tell much difference between any of the Sandvik cutlery steels. My Manly Wasp in 12C27 (HRC 60/61) holds a fantastic edge. Sandvik says on its website, “12C27 is Sandvik's most well-rounded knife steel with excellent edge performance allowing razor sharpness, high hardness, exceptional toughness and good corrosion resistance. Continuous improvement over a period of 45 years has evolved it into the high performing steel grade it is today. The composition is tighter, the purity level is much higher and the fine carbide microstructure of today is far from how Sandvik 12C27 knife steel of the sixties looked. With a hardness range of 54-61 HRC, high toughness, scary sharpness and good corrosion resistance, Sandvik 12C27 is the recommended grade for hunting knives, pocket knives, camping knives, high-end chef's knives and tactical knives.” 13C26 may have a little higher corrosion resistance, but I doubt it would make a while lot of difference in actual use. Blade geometry and heat treatment can make a big difference. Mora uses 12C27 extensively,
