- Nov 20, 2005
You all will have to make your own call with regard to railroad tie use in a landscape. Creosote is a heavy semi-volatile as I recall and likely does not penetrate the soil zone deeply before being bound up with clay particles. Could be wrong about that. Certainly not a chemical you want finding it's way into vegetables. I would suspect root crops would be the most impacted if impacted at all with a few RR ties around.
Everything is bursting with life right now in Southeast Tennessee. This may seem early, but it is fairly typical of here for late February. Some trees are starting to leaf out and certainly the early flowering shrubs are about to bloom. I suspect I will be doing my first lawn mowing this coming week to even things out and clean up remaining leaves and so forth. The grass (fescue mostly) is growing, but there are a lot of high and low spots at the moment. I hope to have time to start making wild flower runs to the woods in a couple weeks to catch the blood root and trout lily blooming. Pretty much totally missed the spring wildflower time last year due to being busy with work.
I keep a small pile of top soil that mostly has come from when I planted trees and so forth (ie place I dump the wheel barrow). I use it periodically when a spot needs a little dirt.
Taldesta, what is that yellow wheel thingie at the edge of your bed in your pictures from your last post? I am not much into real formal yard art. It simply doesn't "fit my yard scape".
