2022 GEC #81 Coon Skinner
Now I might consider getting a yellow bone version!
It's a sleek looker, and that Micarta looks fine, but not on my watch :D
I like the look of that Micarta (would look nice on a #71 or other F&F), the shield looks good and I like the overall Tidioute aesthetic of that one in particular, but I’ve just never been big on the long California clip blade profile. Still probably a pass for me… maybe. 😁
You could always ask mrknife mrknife for his opinion about a blade-delete...;) I might have to opt for deleting both😁
I got in on the CK reserve but was pretty late. I really hope there’s a yellow bone left when I get the notification. I’ll buy regardless because I reserved but that’s really the only one I care about.
I'm hoping I was early enough for snakewood, but will be happy with any cover.
I personally love the California clip on my possum skinner, but this may have one too many. Already thinking about a long coping modification 🤔
This one is a little different with two muskrat blades. It is very much a purpose-built knife with skinning in mind. When one blade gets dull…switch to the other.
I’ve never used a folder to clean game before. How does one go about thoroughly cleaning a folder knowing it can’t be taken apart to get all the nooks along with reapplying a corrosion inhibitor?
I've used the same method that I use when flushing out a fresh-from-factory knife. Wash in hot, soapy water, working the action, blast with some compressed air and then treat with mineral oil. I also would advise cleaning shortly after processing the animal, it's a lot easier to do before the blood and fat gets caked on there.
Do you just kind of go crazy with the mineral oil to make sure it permeates every little nook and cranny?
In my experience, mineral oil does a pretty good job of penetrating the joints on its own so I don't feel the need to go too crazy. I will usually apply with a q-tip, work the blade(s) back and forth to make sure it gets in there (you'll start seeing it bead on the back spring) and then I wipe away the excess.
Awesome, thanks so much for the walkthrough on it. I’ve always hesitated because of concern that I couldn’t adequately clean a folder, but you’ve helped alleviate that.
I wonder why the main blade on those doesn't say "Titusville, PA"? Seems like there's plenty of space left on the tang. Or is it on the pile side or on a second blade's mark side?
