My GSO 5 is in 3V only, and I have produced spotting on my 4.1 before because I didn't clean it after food prep. Two things that affect the corrosion resistance of the same steel would be surface finish and Heat treat. I'm no HT expert so I can only speak anecdotally, but various HT protocols can change how a steel reacts. The surface finish is a little more straight forward. Guy has in the past stonewashed his blades and the overall surface finish was very smooth, IE less surface area/less chance to develop rust. The new finish is a peened style, not sure how it effects things as it looks to result in a matte orange peal style finish. Straight off the grinder finish, or sanded finish as I think most BRKT knives are, leaves very small scratches all over, which looks nice but results in a ton of exposed inner steel which can result in more spots to rust.
This is spot on (pun intended) :thumbup:
I heavily used my stonewashed GSO-5.1 and GSO-10 in 3V, and the GSO-10 developed "freckles" (pitting) and some light surface rust after not being properly cleaned and left sheathed overnight. Here is a video of me cleaning it:
[video=youtube;IZe4T50nrog]https://www.youtube.com/watch?v=IZe4T50nrog[/video]
l love that GSO-10, and per Silver's older thread, I think I'll name her "Anne" since she has ruddy hair (micarta handle) and cute freckles
I have an old-spec GSO-4.1 with the new HT and finish 3V, also used heavily. The only corrosion I saw was a
teeny bit of spotting near the edge after doing some kitchen work and then sheathing the knife and leaving it over-night to see what would develop.
[video=youtube;tusmZwVfgM4]https://www.youtube.com/watch?v=tusmZwVfgM4[/video]
I should mention that that knife was used to butcher a few roosters and, most recently, to field-dress a large whitetail in a marshy area while sleeting. It was rinsed with water, briefly dried on a towel, and re-sheathed. No spots developed.
In my hard use of the 3V in smaller knives like the GSO-4.1, the only major damaged I caused the edge was cutting through folded lip of a steel can. The same use damaged my 20CV Necker II in identical fashion. Using a diamond (DMT) hone, restoring the same amount of edge on either knife took approximately the same amount of time. Here is an older video of an M390 GSO-4.1 - the edge had a few spots with rolls or microchips by the end but could still push-cut receipt paper.
[video=youtube;pVsKMAlYAcU]https://www.youtube.com/watch?v=pVsKMAlYAcU[/video]
My wife prefers to use stainless steels in her kitchen and garden because she is often too busy to get back to cleaning her tools until much later. I have no hesitation about choosing either, but I will mention that the properties of CPM-3V tend toward the uses for which most of the S! knives were designed. CPM-20CV excels and being stainless AND highly abrasion-resistant, but most of us don't need the level of abrasion resistance it is capable of, and the geometry of S! Knives tend to be thicker (>0.020" behind the edge) than desired for optimal slicing performance, geared more toward lateral strength and impact resistance.
BTW, if guy decided to use 420HC in a budget line of knives (quite stainless but low abrasion-resistance), I'd be all over it.
