- Feb 3, 2020
Hi All -
I recently received my 2x72 grinder and set it up over the weekend and have a couple questions regarding mainly vibrations and belt wobble.
Regarding belt wobble. After about 6 motor remounts I have a few belts that run dead on. However 7 out 8 of my Norton belts wobble. Is that a normal hit rate? Some are pretty small while some are what I would consider wobbly. Should I be expecting a majority of belts to have at least a bit of play in them? Or should the majority be dead on?
The second question is around vibrations which bother me a bit more. I am getting some fairly significant vibrations. I set a silicone shot glass of water on the work rest in the lower tool slot with either the platen or the contact wheel in the upper slot. The glass will start vibrating and then start walking around. Is that normal? I am about to drive myself nuts trying to diagnose the problem, and I wanted to make sure I am not chasing my tail here.
The third thing I noticed is that the idler wheels on the platen assembly seem to heat up pretty quick. Is that normal just due to them being small (2"). They don't seem to free spin super great which I am thinking is causing some extra heat. I have loosened the bolts holding them in place nearly as much as I can while still keeping them "tight".
Thanks in advance.
Colby
Thanks in advance.
Colby
