- Oct 19, 2010
I have finally got my hiking gear together for this summer. I picked up many new items in the past few months, New Tent, Sleeping Bag / Pad, Backpack, Knives, etc. This weekend I got all my gear together for a little testing. So I loaded up my new Kelty Redwing 50 and trekked out to the backyard. All in all I am very pleased with all the gear here and am looking forward to some long weekends in the mountains this year. Here are some brief reviews and a complete gear list for what I’ll be carrying this year.
KELTY REDWING 50
Capacity – 3100 ci / 51 Liter
Weight – 3 lbs 9 ounces
Dimensions – 25x18x14.5 Inches
Material – 420D Polyester Ball Shadow
Suspension – Fixed
Size Purchased - M/L: 17.5" - 21" / 44 - 53 cm
This seems to be a well thought out pack. It carries comfortably with 35 lbs of gear. Side pockets fit a 1 liter Nalgene bottle perfectly. Front slip pocket is convenient for maps and compass. Organizational pockets are ok for flatter items. The Suspension System does not stand up to the comfort of other big name packs, but is quite comfortable considering the price tag. The pack has webbing on the bottom that alternates from 2 inch to 1.5 inch loops, and works great for strapping on a sleeping pad or tent. The daisy chain on the front is one thing I don’t care for, I would prefer some Molle / Pals webbing on this panel. Also there is not hanger for a hydration bladder, this does not matter much to me personally because I am not using a bladder, but I would imagine some who would prefer something to hand their water bladder from. All in all I am very pleased with the Kelty Redwing 50 for a 3 day / 3 season pack.
See what fits in the Kelty Redwing below…
Go-Lite ShangriLa 2 Nest (Net and Floor Only)
Weight -1 lb. 8 ounces
Dimensions – 7’6” x 4’6” / 33.75 sq. feet
Materials – No-See-Um Mesh / Nylon Floor
Combined with 8’x10’ Nylon Tarp, Equinox 56”x90” Terrapin Poncho, 12-Aluminum Tent Stakes and 25’ of paracord, and two hinking poles, I was able to create a great 3 season / 2 person shelter for under $150. All contents listed above easily fits into the stuff sack that comes with Shangrila Nest. 33.75 sq. feet is just enough room for two adults with sleeping bags, or 1 adult + gear. Not much room to move around but considering the whole kit comes in at 4 lbs. it is a reasonable trade off. I think you could expect to see a bit of moisture in a driving rain with this set up as the ends of the shelter are relatively open to the elements. Pack a couple extra garbage bags to close off the ends in a pinch.
ESEE 4P-MB with Pouch and Survival Tin
O.A Length: 9.0"
Cutting Edge length: 4.06"
O.A. Blade Length: 4.5"
Maximum thickness: 3/16"
Blade Width: 1.25"
Weight: 7.4 ounces (knife only)
1095 Steel - 57 Rc.
Manufactured by Rowen this for me is the perfect bush craft knife. Capable of handling most any task in the woods and light enough that you barley notice it is with you. Paired with the Molle back and pouch this adds another level of survival gear that can be worn on your belt comfortably, even when you have a backpack with waist belt on. I have placed ESEE in the same category as Glock in my gear list, meaning if it has their name on it, you can bet your life on it.
ESEE Izula
O.A Length: 6.25"
Blade Length (end of handle to tip): 2.88"
Cutting Edge Length: 2 5/8"
O.A. Blade Length: 2 3/4"
Maximum Thickness: .156"
Weight: 2 Ounces (Knife Only)
1095 Steel - 57 Rc.
Blade Width: 1.0"
Same fantastic durability and finish as my ESEE 4, but in a smaller package. This is actually my go to knife. After using this knife every weekend for the past 6 months I am extremely happy with the performance. It gets extremely sharp and stays that way for quite some time.
PUR Hiker Water Filter
I have been using this filter a couple times a year for the past 10 years. It has held up well. I just changed the filter this past year which is almost as expensive as purchasing a new pump all together. I have never had any type of failure with this system but I have always used in cold, fast moving water.
Snow Peak Giga Power Stove and Cup
Stove:
Fuel Type: Canister / Isobutene-propane
Weight: 3.27 oz
Dimensions: 3.6x2x1.8 inches
Cup:
Material: Titanium
Capacity: 21.2 oz
Weight: 2.8 oz
Fuel Canister and Stove fit inside the cup, add a plastic spoon to supplied pouch for a cook set that weighs in just under 2 lbs. I have just started using this set and am pleased thus far. Fuel canisters provide 75 minutes of burn time on this stove and boils water in about 7 minutes. I am very pleased with Snow Peak’s cook set.
First Priority was to get the fire and some coffee going this morning. Starbucks VIA Ready brew turned out pretty good.
Snugpak Sleeper Lite Sleeping Bag
Weight: 3.6 lbs
Materials: Lightweight nylon exterior. Filled with 'Insufil', a siliconized hollowfiber
Pack size: 16 X 8"
Measures: 86"
Comfort temp 32° F, low 18° F
This is a well built sleeping bag. I slept in this bag with Thermarest Scout sleeping pad. The bag met all my expectations. Temperatures pushed down to about 40 degrees and I stayed warm all night. I did have a little trouble with the zippers but I expect this will improve with use. I would not push this bag past 32 degrees.
What Fits in the KELTY REDWING?
3 Day / 2 Night Gear List
Total Weight = 35 Lbs. (With Food and Water)
Backpack
-Kelty Red Wing 50 (3100 ci)
-Maxpedition Medium Tactile Pocket (Conceal Carry on waist belt)
-Maxpedition Mini Rolly Poly (Nalgene Bottle on waist belt)
-Various Stuff Sacks and Dry Bags
Shelter / Sleeping Gear
-GoLite ShangriLa 2 Nest
-8’x10’ Nylon Tarp
-Snugpak Sleeper Lite Sleeping Bag
-Thermarest Scout Sleeping Pad – Regular
-12 – Aluminum Tent Stakes
-25’ Para Cord
Cooking Gear
-Snow Peak Stove
-Snow Peak Pot / Cup
-2- Fuel Canister
-2-Spoons
Food
-2 –Single Serving Mountain House Meals
-2 – Double Serving Mountain House Meals
-Granola Bars, Beef Jerky, Nuts, etc
-Salt, Pepper, Sweetener
Hydration
-2 – 1 Liter Nalgene Bottles
-1 – 4 Liter Platypus Water Pouch w/spout
-PUR / Katydyn Pro Hiker Water Filter
-Water Purification Tablets
-Powder Gatorade / Starbucks VIA Ready brew Coffee
Hygiene
-Toilet Paper
-Wet Wipes
-Hand Sanitizer
-4 oz. Camp Soap
-MSR Pack Towel – Medium
-Sun Screen
-Chap Stick
-Bug Spray w/Deet
Clothing
-Fleece Jacket
-2 Pair Non Cotton Socks
-2 Boxer
-2 Non Cotton T-Shirt
-Bandanna / Hat
-Mechanix Gloves
-Sun Glasses
Navigation
-Topo Trail Map
-Compass
-Ranger Beads
Tool / Misc. Gear
-ESEE 4P-MB w/ Pouch
*Water Bag / Purification Pills
*Signal Mirror
*Fire Steel
*Survival Info Card
*ESEE AH-1
*2 Fish Hooks
*2 Mini Lures
*4 Sinkers
*30’ 50# Fish Line
*Mini LED Light
-ESEE Izula
-Coleman Camp Saw
-Trowel
-Gerber Plier Tool
-75’ Orange Para Cord
-50’ Black Para Cord
-Cell Phone /Ipod
-LED Flash Light –Extra Battery
-Mini Led Light, Whistle, Ranger Beads (Attached to Pack Strap)
-Glock 23
-Write in Rain Note Pad
-Equinox Poncho
Medical / Emergency Gear
-Adventure Medical .5 Kit + Quick Clot
-SPOT Locator
ESEE Small Pack PSK
Fire:
-ESEE Fire Kit w/ PJ Cotton Ball
Water:
-2 – 5”x7” Heavy duty Zip Top Bag (1 Liter Capacity)
-6 – Aquamira Water Purification Tablets
Shelter:
-Heat Sheet Blanket (Single Person)
-Contractor Grade Trash Bag (Cut Open 72”x54”
Rescue / Navigation:
-Whistle
-Signal Mirror
-Compass
-ESEE Survival Card Set
-ESEE Navigation Card Set
Tools / Misc:
-TOPS Survival Saw
-Compact Multi-Tool
-2- ESEE AH-1 w/ Fletching & Glue Kit
-3- Large Key Ring
-3- Small Key Ring
-Key Chain Light
-35’ Black 550 Cord (Woven Shoulder Strap)
-6’ Light Bungee Cord
-18’ Heavy Nylon Thread
-Sewing Needle
-24” x 12” Aluminum Foil
-Small Roll Duct Tape
-3 Sheets Rite in Rain Paper
-Black Pen
-Compact Fishing Kit
*6 Hooks (Various Sizes)
*40’ - 50 Lb. Spider Wire Fish Line
*6 Split Pea Sinkers (Various Sizes)
*4 Gummy Bait
First Aid Kit:
-2- Lg. Band Aid
-1-Anitseptic Wipes
-2-Imodium
-2-Motrin
-2- Benadryl
-2- 2x2 Gauze
-1- 3”x3” Gauze
-Tourniquet Band
-Tick Tweezers
-48” Medical Tape
Thanks for looking.....
KELTY REDWING 50
Suspension – Fixed
O.A Length: 9.0"
Blade Width: 1.25"
1095 Steel - 57 Rc.
ESEE Izula
O.A Length: 6.25"
1095 Steel - 57 Rc.
Blade Width: 1.0"
Stove:
Weight: 3.27 oz
Cup:
Material: Titanium
Capacity: 21.2 oz
Weight: 2.8 oz
Weight: 3.6 lbs
Pack size: 16 X 8"
Measures: 86"
Backpack
-8’x10’ Nylon Tarp
-25’ Para Cord
Cooking Gear
-Snow Peak Stove
-2- Fuel Canister
-2-Spoons
Food
Hydration
Hygiene
-Toilet Paper
-Wet Wipes
-Hand Sanitizer
-4 oz. Camp Soap
-Sun Screen
-Chap Stick
-Bug Spray w/Deet
Clothing
-Fleece Jacket
-2 Boxer
-Bandanna / Hat
-Mechanix Gloves
-Sun Glasses
Navigation
-Topo Trail Map
-Compass
-Ranger Beads
Tool / Misc. Gear
*Signal Mirror
*Fire Steel
*Survival Info Card
*ESEE AH-1
*2 Fish Hooks
*2 Mini Lures
*4 Sinkers
*30’ 50# Fish Line
*Mini LED Light
-ESEE Izula
-Coleman Camp Saw
-Trowel
-Gerber Plier Tool
-Cell Phone /Ipod
-Glock 23
-Equinox Poncho
-SPOT Locator
ESEE Small Pack PSK
Fire:
Water:
Shelter:
-Whistle
-Signal Mirror
-Compass
Tools / Misc:
-TOPS Survival Saw
-Compact Multi-Tool
-3- Large Key Ring
-3- Small Key Ring
-Key Chain Light
-Sewing Needle
-Black Pen
*4 Gummy Bait
First Aid Kit:
-2- Lg. Band Aid
-1-Anitseptic Wipes
-2-Imodium
-2-Motrin
-2- Benadryl
-2- 2x2 Gauze
-1- 3”x3” Gauze
-Tourniquet Band
-Tick Tweezers
-48” Medical Tape
