You should tell us about the charpy numbers you've gotten for your own tests with your heat treats for W2, 52100, and 80crv2!
Unless he has a charpy tester, he did not create any. He can give his toughness impressions though.
Except for a situation where there were errors/inpurities in the steel. For given thickness softer blade will be more forgiving. That is why you make laminated blades, with extra hard, yet thin central piece and softer sides. full thickness lets say aogami blade would be more fragile.They're both going to break at the same level of stress... it's just a matter of how they perform up to that point. A blade with a soft back will take a set before it breaks, a fully-hardened blade will come back to straight or nearly straight after being subjected to the same pressure.
He claimed he had one, and gave a charpy value to a knife with 80crv2 as being 60 @ 60 rockwell.
Cobalt - agree. I would make similar calls as you've done so. However if you are willing to entertain sub 2um grain size possibility, it could offer much higher toughness & strength then good old ht. LOL - if knives in Bodog's PA perform poorly, well I will flush stuff I said about ultra fine grain claims down the toilet myself as well
bluntcut, if your testing indicates that 80crv2 is both tougher and holds a better edge than 52100, I would believe you. I personally do not think that will be the case. But I am only guessing.
80crv2 might not hold a better edge than 52100, but it should still hold an edge that is not too far behind. I do believe that 80crv2 is tougher than 52100, and prob close to the realm of 3v toughness.
Perhaps a misinterpretation somewhere, I thought I consistently stated 52100 has better edge retention than 80crv2. Furthermore likely I also found my latest ht 52100 toughness level may have past 80crv2. It is unproven claims so burden is on me to prove at qualitative and quantitative and 3rd party verified so... to seen
It is a major pain to poke a message on tiny phone touch kb.
There should be some independent tests of bluntcut's knives here within the next couple of weeks. 52100, CruForgeV, 1095, M2, and W2 will be tested.
I am using a w2 gyuto from Luong at work and it is performing really well. My only problem is that is such a nice knife I find myself babying it. Luong laughs and says break it in half, I will make another. He is a gem and taught me so much about metals and sharpening. Great guy to have on this site. Russ
Seems comparable to these other steels. Properties should be very similar.
80CrV2
C(% 0.75-0.84
Si(򟘲.15-0.35
Mn(򟘲.15-0.35
P(򟘲.025
S(% 0.020
Cr(% 0.40-0.70
Ni(%Max 0.25
V(%)0.10-0.20
L6
C - 0.7
Mn - 0.6
Si - 0.25
Cr - 0.7
Ni - 1.4
52100
C 0.980 - 1.10
Cr 1.30 - 1.60
Mn 0.250 - 0.450
Si 0.150 - 0.300
S ≤ 0.0250
P ≤ 0.0250
O-1
C - 0.85-1
Si - 0.1 - 0.5
Mn - 1 - 1.4
Cr - 0.4 - 0.7
V - 0.3
W - 0.4- 0 .6
W1
C - 0.95-1.05
Mn - 0.3-0.4
Si - 0.1-0.25
Cr - 0.15
Mo - 0.1
W - 0.15
V - 0.1
P - 0.025
S - 0.025
