- Nov 10, 2011
O1 vs 80CrV2 will be about the same cost per blade for steel, HT is similar, 80CrV2 needs short soak both do well in 12 second oil, both are high carbon and will rust if not kept clean and dry
O1: easy to source in whatever thickness you need as Precision Ground Flat Stock, 0.95 carbon gives higher as quenched hardness, 1.25 manganese helps insure thru hardening, 0.5 tungsten helps with edge retention. you don't want to temper over 400F due to hydrogen embrittlement, this would be my choice for thin high hardness blades, 3/64" blades at Rc64 cut like a laser.
80CrV2: not many sources unless you are buying big pieces(2' x 6') or 100' rolls, would be my choice for a chopper/cleaver where you are willing to swap high hardness for increased toughness and resistance to chipping
scott
scott
