Tom, all it takes is $$$$.
Peter, it's one of those gator things on the grinder. Lots of norax in the background tho.
Higgy, yup it's a 20" simulator.
Rob, Yes that's the other custom platen on you made in the background. And yes again I use it all the time. Still for knife sharpening. (FWIW, I tilt the platen back to 15 degrees, run the belt backwards, and hold the knife parallel with the ground. I can't sharpen any other way.)
Mouse pad!!! You're right why didn't I think of that?
Now that I have the curved platen theres a couple of changes I'd like to make. Mostly for the friction problem.
Here's the mod
The thing heats up, so some more holes might help dissipate the heat better. I'd also cut out along those green lines. That would reduce the surface area to just what I need. Then trim down the height to fit between the idler wheels.
There is something I didn't anticipate using a large diameter 'wheel' (real or simluated). It's hard to make a straight grind line (for me anyway). You see on a flat platen if the tang is a little high or low it doesn't really effect the line. With my 8" wheel once the groove is set the blade tracks in there helping to keep things straight.
But! with a large diameter it doesn't track the groove so solidly - making it easy to tilt. However, if you do tilt up or down on the tang the grind line is shot.
Not a big problem with practice, but it is very different than flat or 8/10" hollow grinding.
Steve
