- Mar 26, 2004
This is a little device I made to make symetric and/or parallel fullers on blades.
I was making a custom ordered blade and I messed up, so I built this in 20 mins with ordinary pieces. Probably there's already something similar in the US market, but maybe this low tech solution can help someone, so I took some pictures
For this blade, I used a 3mm cutting disk on a bench grinder.
In this particular case, I didn't care for scratches as I'd still had to mirror polish the blade, but you can use a piece of clothing or rubber between the blade and the screws to avoid them.
Regards,
Ariel
Regards,
Ariel
