LaMess I used a mix of vacume pump oil(mineral oil) and used auto tranny fluid, about half and half.
Bill, I can't coment on 5160 much, because I havnt played with it that much.
To give you an idea of one test where L-6 outshined everything, I had a couple of blades that were in the scrap bin from misgrinding and decided to cut some 6 penny nails. The 52100 cut three or four nails with no edge damage, then chiped out. The L-6 blade cut about 10 nails and the only damage was a dulled edge, slightly blunted. All cuts were in the same spot on the blade with the nails resting against a piece of mild steel and drove through the nails with a 3lb. hammer. I know this is not a scientific test, but some times you just have to play around. Now, my heat treat may not be perfect, I'm continualy refining and testing, but those results and others showed me that while 52100 is very tough, L-6 with the addition of nickle has less metal fatige.
One other test that I do for hunting sized knives is that I have a old dried cow shin bone that I chop some hunks out with the final edge. I like to get as fine an edge geomitry as I can, and if it's to fine the bone chop will wrinkle the edge, then I change sharping angle slightly. I have noticed that stainless requirs a thicker edge, and that carbon steels will take a fine edge without damage. I also chop hardwood and cut lots of rope, but the bone chop I think comes close to acidental impacts while procesing game.
anybody have any other sugestions for test media I'd like to here them.
