- May 18, 1999
Due to all of the confusion of the weather and me being in and outta the hospital Barb and me finally got our Smokin Pro all put together a few days ago. Barb and her brother had done the biggest part of the work.
There were a couple of wires that the weld had broken on the Bro finally got around to taking to the shop and welded last night as well as putting some stainless expanded metal on the fire grates to help them last longer.
So today we fired up the Smokin Pro to burn it in to get any of the oil that was on it to burn off so it wouldn't kill us when we start cookin on it.
I did a little bit of chopping today with one of the Sanu made Cherokee Roses.
I even did a little prying with it with no problems.
I also stabbed the point into that old piece of chopping blocks we still have on the patio from when the Kookeri Khonvention was here and very carefully pulled from side to
side.
I know the wood is a little soft and giving, but I pulled it over about 20* on both sides with the point returning to
true.
This is the thicker of the two knives.
I chopped some oak in two that was about 1/2" thick and ranging from 1" to 3" wide.
The Cherokee Rose is shaped just like a good axe with its geometry, doesn't hang up in the wood,
cuts plenty deep enough, I was getting a good steady 1" depth each chop with my not so strong arms right now.
Some of the ones in better shape I'm sure will do much
better.
The prying was done in a piece I was trying to split until I realized it was Sycamore and it wasn't gonna split easily.
I chopped into the side of it sorta like making a huge fuzz stick and then got a couple of places to start spliting and that's when I pryed with it in order to break the chunks off.
I told y'all it was a very,very,very mini report. However what little I did has made me anxious to do even more as I start to get in better and better shape.
The handle is so very comfortable it's almost unbelieveable to me!!!!
I sure wish I could design 'em like this.
The only downside is that both handles were cracked before I started I imagine due to the weather changes here, this is in no way the fault of H.I.
I have Bondini2 on both of them now.
The upside is the beauty of the wood. I did a little scrapeing on it and I am still not sure of what it may be. After I get them glued up and sealed in those areas I will sand and wash with Murphy's to see what it really looks like.All I know is it's the most beautiful wood I have seen come outta BirGhorka and Nepal!!!!!!!!!!
side.
true.
better.
