Deryk Munrole on A2 (
http://www.bladegallery.com/dcmunroe.htm):
A2 Tool Steel (typical analysis: C - 1.00%, Mo - 1.00%, Cr - 5.00%, V - 0.25%)
One of my favorites in terms of pure Zen-like cutting power. A2 is an extremely tough, fine-grained tool steel with excellent flexibility and wear resisting capabilities. A good choice for stock removal Japanese-style blades including full length katana. The exceptional toughness makes it a great choice for blades that are going to endure shock and bending. A2, with the proper edge geometry, will get downright SPOOKY-sharp. For some reason, I can get A2 sharper than any other steel I've used so far. Edge-holding is very reasonable and the relative ease of field sharpening is a good bonus.
As with all tool steels, the main drawback is the lack of corrosion resistance. Even with the 5% chrome A2 is still quite susceptible to staining if not cared for, although perhaps not as much as O1.
Mike Snody on A2 (
http://www.snodyknives.com/MS_Knives_Materials.htm):
A2 is an air hardening carbon tool steel. A2 exhibits good wear resistance and great toughness. A2 steel will get screaming sharp and is a good choice for larger knives where toughness is important. A2 steel is comprised of 1.00% carbon and 5.25% chromium. A2 is not stainless and must be properly cared for to prevent corrosion. A2 is considered to have the best compromise between wear resistance and toughness of any of the standard cold work tool steels.
A. G. Russell on A2 (
http://www.agrussell.com/knife_information/knife_encyclopedia/a.html#A-2):
An excellent air hardening tool steel used by handmade knife makers and by speciality makers like Bark River as well. First maker I know of using it was Harry Morseth in the early 1930s. Performs best at about 60-61 Rc (see hardness). For many years my favorite as well as Ron Lake's. It contains about 1% Carbon, 1% Molybdenum, and 5% Chromium.
Joe Talmadge on A2 (in the BladeForums FAQs):
An excellent air-hardening tool steel, it is known for its great toughness and good edge holding. As an air-hardening steel, so don't expect it to be differentially tempered. Its outstanding toughness makes it a frequent choice for combat knives. Chris Reeve and Phil Hartsfield both use A-2, and Blackjack made a few models from A-2.
Having never seen a direct comparision, I would guess that A2 would be superior to S30V in the categories you list except corrosion resistance and abrasion resistance. If you are willing to live with the maintenance of A2, you could think about CPM-3V which has superior toughness and abrasion resistance compared to A2, and equal abrasion resistance to S30V.
