- Nov 28, 2021
ACEBEAM New X75 is the brightest power bank flashlight in its class (built in 4 x 21700 battery), features 12 CREE LEDs, and along with a wide reflector it produces an unprecedented 80,000 Lumens!
The X75 utilizes boost circuit; innovative intelligent cooling fan for efficient heat dissipation, scientific cooling air duct design, detachable and maintainable cooling fan, and Type-C PD60~100W charging/discharging function - a truly uncompromising solution for the demanding professional user.
This tremendous power is focused through that reflector and can reach distances of up to 1150 meters (3773 feet), perfect for long range spotting as well as search&rescue,outdoor activities and emergency situations.
Lighting up a park!!
Features:
* Outdoor Portable USB PD Power Bank Flashlight 80,000 lumens max output
* USB Type-C PD60W fast charging ; 1.5 hours for full charging. Also can compatible PD100W fast charging(Max); 1 hour for full charging.
* Built-in dual intelligent temperature regulation systems
* Intelligent cooling fan and Intelligent thermal control module
* Detachable,maintainable and waterproof cooling fan(IP68)
* Can set the Windy mode or Non-wind mode
* Up to 98% high efficient constant current circuit
* Momentary Turbo activation rapidly responds to emergency situations
* Pure copper heat dissipation piece for high efficient heat dissipation
* Color-changing silicone sleeve monitors temperature of flashlight and protects for anti-impact
* Patented mechanical safe lock-No accidental activation
* IP68 standard waterproof
Learn more: https://www.acebeam.com/x75
Features:
